Horner XL7 PLC and Eaton MMX VFD Control signal issue.
A17G
Feb 2024
Indiana
Hello, I’m new to this forum and if I’m posting incorrectly let me know. I’ve been having an issue I can’t seem to figure out. I’m sure it’s something simple I’m missing.
I’m trying to run an Eaton MMX VFD with an Analog 4-20ma output and Digital out from a Horner XL7. I can start the VFD/pump with no problem with the DO controlling a relay that closes contact to start it. But when I do that my 4-20ma signal immediately drops to 0ma even though it reads what I’m outputing when not starting the vfd. I think maybe it’s grounding issue but can’t seem to figure it out. All parameters are correct on the vfd. It works if I source the 4-20ma signal with a meter. Any help would be greatly appreciated. Thank you.
A little bit more info will help a lot.
The XL7 analog can be configured for Current or Voltage using the built in configuration via software (cScape).
How is the VFD wired & setup?
How is the XL7 wired and setup?
I was loading a program onto an XE1e2 PLC and it got stuck on these two windows and won't progress. It won't let me connect from the PC to reload...
103
I am trying to set up a piece of equipment with a Horner HE-X4R. I'd like to use structured text and so far I'm just trying to get a basic On/off...
108
I am having a problem communicating my PLC with Drive via Modbus connection. I start by opening the port and there is no problem, but then when I...
264
I seem to be making this harder than it should be, and Its not making any sense. I simply need to move a real variable to two integer variables...
1,015
I am using Cscape 9.9 service pack 8. I am writing my program as a variable based program not register based. When I try and have the output...
861
