simulation setup using horner OCS using structured text (Cscape)
jdk202
Apr 2024
OK
I am trying to set up a piece of equipment with a Horner HE-X4R. I'd like to use structured text and so far I'm just trying to get a basic On/off switch set up using this. The code is just several lines and assigned the variables to two buttons and the Motor_RUN to an indicator light on the screen.
IF PBMotor_ON = TRUE OR Motor_RUN = TRUE THEN
Motor_RUN := TRUE;
ELSIF PBMotor_ON = FALSE OR PBMotor_OFF = TRUE THEN
Motor_RUN := FALSE;
END_IF;
I'd like to test this without wiring it into the system but the simulation option is grayed out when I go into debug mode. Does anyone know what I need to do in order to do a simulation?
94
hello every one. i'm new to tiaportal, i have created new project and HMI screen the program works fine with PLC-sim, but when i try to cntrol the...
432
I am looking to upgrade a CompactLogix on V18 to an L83E on V32 which is currently using a Beijer E1151. Does anyone know if the E1151 is directly...
653
I use the HMI simulation as our production lines are pretty big and we've put an upgrade in over the last couple of months and I've used it most...
740
Hi Any one here please helpmein simulation of s7 300 plc program with factory io. how to connect. plcsim 5 doesnot have option of s7 300 ..:
1,016
