boxofrelays
I think there might be an issue between versapro and LM90 programing. There is a slight difference in memory utilization in the PLC CPU between those two programming products -so use the programming platform that the PLC was programmed with. I have tried switching back and forth between LM90 and Versapro to see if it could be done. It did not work for me. -Chris
