ControlLogix 1756-HYD2 fault
Martindag
Sep 2009
quebec
227
Hi there!
I posted few days ago about a fault i had with my motion.
I did some cable check and replacement and it didnt solve my problem yet but found something different on the card in found (Check attachment)
On the other 3 axis, when i read #29/31 or #30/32 i get between 3-4VDC
but the axis in fault when i read it i got 0 VDC. and the Channel 1 LED blink RED.
The sensor mounted on the axis cylinder is a Temposonic linear displacement rod to give the position of that cylinder.
I tried a new spare cylinder with a other temposonic mounted on it and still got the same fault and replaced the section of cable that were the most damaged.
Was wondering if you guys had any other suggestion what should i check from there i'm running out of ideas lol.
Thanks!
We have a project where we have the 1756-L82Es in redundancy with Remote IO Backplant via EN2TRs. Everything works and is redundant but we can...
384
Hello, We have a customer with a 1756-L72 ControlLogix PLC. They have recently got a T01:C62 Fault Code. I am trying to figure out how to...
1,094
PN1651 - ControlLogix 1756-OF8/B modules may exhibit spurious channel 4 through 7 faults. Rockwell just released this and we have an upcoming...
1,083
I was wondering if anyone else has had issues with the PA75 bricking on power ups. We had 2 that were a year old brick on us. 1 bricked when the...
873
I have followed several videos and tutorials that suggest when using the MSG function to enter 2,xxx.xxx.xxx in the Path box in order to connect...
1,413
