connecting two HMI to modicon m340
aryautomation
Nov 2006
texas
34
I have connected two HMI to modicon m340 via an ethernet switch and trying to program the pls using Unity Pro.How can I link these two hmi's to the plc ethernet port. In the program after dbl clicking on the ethernet port of the PLC , it just allow me to link only one touch panel
You need to have an IP for each device in the same class IP.
On the ethernet port of the M340 you write an IP in the same calss ip with HMI IP.
For communication with first HMI you must create the variables in PLC with same address that you have created in the first HMI.
For communication with second HMI you must create the variables in PLC with same address that you have created in the second HMI.
Or, of course, you could use C-more panels, and serve tags from one, to the other, without being limited at the PLC connection point.....
(just sayin')
I like c-more and ab. But my customer has asked me to use m340 and unity programming and magelis. I have never seen such an awkward programming. No wonder modicon is losing the market share.
Good Day to all of you, this is my first post, i will try to explain as best as possible, english is not my natural language. I am performing an...
92
I am trying to backup a program on a Windows 10 IPC running an application written in TIA v16 and download an update. The system has a Siemens...
2,232
Hello everyone! I was wondering if anyone here has any experience setting up a RS PRO HMI to connect to a Micro800 plc? The available drivers...
1,225
I am trying to get a Mitsubishi GT2715 HMI to read and write from a Eurotherm 3508 controller using 4 Wire RS485 Mobus RTU communications. The...
1,323
Hello all, I'm trying to replace an obsolete NT600 touchscreen with the aforementioned EA9-T10CL C-More HMI from Automation Direct, serial...
1,176
