PLC Delta DVP 12SE and HMI Kinco GL043E not propperly connecting
Tecnolaundry
Apr 2024
Aguascalientes
Good Day to all of you, this is my first post, i will try to explain as best as possible, english is not my natural language. I am performing an industrial dryer automation,
i am using PLC Delta DVP12SE and a Kinco GL043E
I am using Modbus to read temperature and humidity for a sensor in com2 for DVP
I am using Ethernet connection for the PLC Delta and HMI, cables work fine i have a tester and show no problem
the really confusing situation is that I can display the humidity and temperature value on the HMI, but i cannot use the M0...M100 memories to act as push buttons, this is very werid since i can read data from modbus but not activating any memory.
Hey guys, I've a requirement that a two different PLC program should work in same system depending upon user input. Consider Program A is used...
1,938
Hello, I'm facing a problem in communication between my delta TP70P-32TP1R HMI and DVP20EX2 PLC. I tried multiple ways in order to set the...
1,364
Dear Experts I have purchased plc from my friend and i am learning delta plc programming but my delta DVP SX series plc and is continuously...
1,306
i have dvp 14ss2 plc and kgk inkjet printer .how to send data via rs232 com port,and if any sample program available please send .
2,074
I require to interface a Honeywell 3310g fixed industrial barcode scanner with Delta DVP-SX PLC. The barcode scanner has a RS232 communication...
4,153
