connecting hall sensor to two different inputs
1955classic
Aug 2014
Auckland
The drawing shows the basics of what i am trying to achieve. The Hall sensor is drawn accurately from a schematic from the supplier.
It is currently using a 12v supply and i cannot change this as it goes to the main engine ecu.
The signal output is a 0-12v square wave.
I need to connect the same sensor signal to another separate frequency counter which has its own sensor outputs as drawn. I have confirmed that the frequency reader 'signal input' is at 5v and each time it is grounded to its own sensor ground output, it counts as one pulse.
Could someone please draw me a schematic of what i could do to connect this. I am mechanically orientated and can purchase and make whatever is needed, i just have no clue as to how and what is needed to get the signal correct
Many thanks in advance
I have 2 PLCs. One is networked to our plant, and the other is networked to the first PLC via a 1756-EN2T. I could easily get the second PLC...
84
Good Day to all of you, this is my first post, i will try to explain as best as possible, english is not my natural language. I am performing an...
94
146
Hello, I was looking to store some values from our FactoryTalk Application using Datalog to a MariaDB. I see there is quite a bit of documentation...
154
I haven't encountered problems connecting to a PLC through VM Ware but I am with this particular machine. I'm running Windows 7 on a Windows 10...
262
