Alternative solution to log into SCADA system than password. (Electronic Access CTL)
Jul 2007
Kiruna
600
Hi All,
I'm looking for an alternative way to gain access to a SCADA system. I can't use passwords because customers will be looking over shoulder sometimes and I cant have people seeing login information. Perhaps something like a one wire bus iButton from Maxim. Has anyone had any experience integrating something like this into PLC\SCADA.
I have an RS232 interface I can use but if such a device existed with some "intelligence" I could hard wire to an input card it would be great.
Hi
I use a password for all commissioning/handover then change it for our service password. An alternative i have seen is to press and hold company logo or similar for a time> if it must be secure use a card scanner or barcode reader
Try a google search for fingerprint or biometric readers, most come with RS232 interfaces, although I'm not sure how you'd get the software to integrate (you may have to write a routine of your own?)
Hello friends, I'm asking a new question here, after thinking a lot about my problem, I wondered if it wouldn't be easier for me to install new...
746
I am using a HMI from PROFACE (GP-4502WW). There is a limitation where I can only include 1 global pop out window. However, there are 2 global pop...
1,436
Hello to all, I'm just starting with using CodeSys. Immediately, I have noticed that Codesys doesn't use data blocks like for example S7 does...
217
Greetings All, I recently decided to start freelancing in Controls and Automation part time, most of my experience has been with Rockwell...
180
Recently I have requested a quote from Magnetek for their Impulse Drives but can't raise a response from them. I've requested a quote FOUR TIMES...
1,079
