Alternative Solution for Having 2 Global Pop Out Window
chngkailiang
Oct 2020
Gelugor
I am using a HMI from PROFACE (GP-4502WW). There is a limitation where I can only include 1 global pop out window. However, there are 2 global pop out window in my project. Although I could just place a window screen on every base screen to serve as the other global pop out window, but it seems too tedious. Is there any alternate approach for this issue?
what calls the popout window? can you use that to trigger Visibility options? One popout can do both duties, on execute of the window opening it can check which called it and set visibilities with that.
Yeah, this is one of the viable option, however, it can't fullfiled what I intended to achieved due to the background cant exactly be transparent. When one of the message box is invisible, the background for the window screen will still be there, it is blocking the base screen.
Hello friends, I'm asking a new question here, after thinking a lot about my problem, I wondered if it wouldn't be easier for me to install new...
747
Hi All, I'm looking for an alternative way to gain access to a SCADA system. I can't use passwords because customers will be looking over...
2,859
Hello to all, I'm just starting with using CodeSys. Immediately, I have noticed that Codesys doesn't use data blocks like for example S7 does...
220
Greetings All, I recently decided to start freelancing in Controls and Automation part time, most of my experience has been with Rockwell...
180
Recently I have requested a quote from Magnetek for their Impulse Drives but can't raise a response from them. I've requested a quote FOUR TIMES...
1,079
