allowed voltage on pushbutton
Another thing us crazies with 230V use is RCDs. At least for lights and sockets where Joe Public generally comes into contact with the zappy bits.
Just my 2 cents. I used to work on a lot of older (ancient) molders and saws in a lumber mill. Almost every one of them was set up with 480 vac controls. A few had been rewired for 120 vac control. Either way, industrial GFCI's were a relatively easy way to make them safer until time and money could be obtained to upgrade the controls.
110V or 230V AC on operating elements are OK, as long as the entire circuit and enclosures are rated for it.
Same as the light switch in the wall switches the 120V or 230V AC directly.
That being said, it is becoming rarer since universally the preference is 24V DC.
About being zapped by 110V or 230V, then the person being zapped is himself to blame by assuming things. Any enclosure within which there is a dangerous voltage must be clearly labelled as such. And there must be a sign insde or outside clearly stating the control voltage used.
No such label or sign ? Well then investigate it before mindlessly touching live circuits !
Just saying...
I haven't read the entire posts here, but nfpa79 - industrial standard for industrial machinery dictates that no new control panels shall have control voltages above 120 volts ( that might have changed recently).
that section of the code is pretty old.
systems built before that rule was implemented was grandfathered in.
I don't have my book with me, I packed it during the move to my new job.
if I a wrong, someone please correct me.
james
Thanks James,
That is what I was looking for. I didn't know where to look.
I looked up the 2018 NFPA 79 and found similar
Just saying...
I agree and it is pretty much the same as proving zero energy which means labels or not and regardless of how big the signs are the person exposed to the hazard has the obligation and responsibility to know exactly what is there or not there.
The answer to the original question however does not change, 24V is the better choice for all the reasons given in this thread.
...the person exposed to the hazard has the obligation and responsibility to know exactly what is there or not there....
My fear is not that a technician opening the panel is not going to realize the danger of the control voltage, it is the operator that may be in danger if the control voltage gets to the surface of the pushbutton or switch, as was what happened in my post of the operator getting electrocuted at a header shop here in Detroit.
I absolutely agree.
Hi, Like the subject say I would like to know when are extended or raised operator allowed for a start function. The machine in question...
4,094
Hello everyone, I'm starting a program for a CompactLogix 5380 series PLC for an upcoming build. I need to send and receive ASCII strings to/from...
1,875
It's 2020; allowed files need to get larger on this forum. The 300kb limit for photo size is getting ridiculous. It's remarkably hard to get a...
1,887
PLC-5 I read this warning from the Help file And my code looks like this, so I appear to be violating both rules yet they work fine. Should...
2,003
