Add a CPU to the library tia portal
If your TIA supports the model you are wanting to add, you can install the HSP support packages. Or use the update tool.
Some of the newer CPU's are not supported by the older software. And as mentioned, some are restricted by what license you have.
Hello The plant is running and there is no shutdown nowadays therefore I can add 1734- AENTR and its card while PLC is in Run? I do not wanna...
367
Hi Guys. I got a 1212C DC/DC/DC with 4 PWM outputs. I thought by adding an SB1222 atop of the CPU would give me more PWM outputs... but...
2,207
Hi all is their any way to add CPU 317-2DP into catalog of simatic5.1. Thanks
1,730
I have ordered a new CPU for a new project. It is not covered in my Step7 (V5.3 SP1). I understand I can download an update for my hardware...
6,989
Hi, I have questions. I have Analog Input that need to put into Ignition Designer. But I don't know how to put?
137
