ADD More PWM outputs to S7-1200 CPU?
Kasperv79
Mar 2012
Copenhagen
48
Hi Guys.
I got a 1212C DC/DC/DC with 4 PWM outputs. I thought by adding an SB1222 atop of the CPU would give me more PWM outputs... but apparently not..
Are there any way that i can add more PWM? either by hardware or software ?
You could probably add remote IO cards, like an ET200SP rack with PWM modules, but I don't think that the 1200 can go above 4 PWM in its own IO.
I assume the limitation has something to do with Siemens trying to push people into their bigger PLC families and profinet enabled drives for bigger applications, but I'm really not sure.
Doesn't sound good..
hmm.. Ive been looking at all CPU's, 1200, they all only have 4 PWM..
SFB49 for S7-300 is a Pwm function, aint there anything likely for 1200?
D
As far as I know, SFB49 was only used with 300 CPUs that had built in IO. The biggest was the 313C, which could also only do up to 4 PWM channels. It didn't allow the 300 to do PWM on any output, just the built in PWM outputs. Exact same concept as the 1200.
I have both an Automation Direct Click Plus PLC and a EA3 series Micro HMI that I’m getting a feeling for before a big project since I haven’t use...
1,225
Hopefully someone has had more experience in this than I have. I was tasked with making a recipe function for a project. I've done so based on...
2,707
The standard Micrologix 1000 PLC comes with N7:0 as integer data file, how can I add 2 more integer files, let say N9:0 and N10:0? I'm using...
12,440
I am an end user of a new RSView SE system (after several years of using and modifying Wonderware). I would like to add a couple of new tags to...
4,972
4,334
