Studio 5000 v30 and FTView v9
ASF
Jun 2012
Australia
3,921
Hi guys,
It seems that v30 of Studio 5000 and v9 of FTView were released this month, both of them now with official support for Windows 10.
Anyone had a chance to play with them yet?
Well after 15 clicks, a validation, 5 tabs, 2 popups and no regard for my available hard drive space, it's downloading. We'll see...
edit: that was for Studio 5k, I don't have the patients for FTVS.
Only 15 clicks? Luxury!
I should probably raise the very important point I found buried in the release notes about v30, which basically says that if you install v30 on a 32-bit OS, v23 and below will stop working.
Also, on any OS, once you install v30, v23 and below will fail to install. So, for the age-old debate of "which order do we install RSLogix in?" we now have a valid reason to say "oldest to newest" 🔨
Ooooof course it does. Classic.
edit: There's some notes way down at the bottom of the release notes that says "Contact Rockwell Automation Support for instructions on disabling the Logix Designer Start page on versions 23 or earlier. Disabling the Start page allows the Logix Designer application to start and run."
So maybe if you disable that horrible start page, maybe they'll run. I may have to experiment with that.
Hi All, apologies I don't have access to a remote IO module to test this out. I have a number of remote IO blocks, each with approx 8 IO cards...
2,178
I want to update from V30.02.00 to V30.02.02 as 5000 keeps crashing while I try to do an upload from a PLC with a large program. I figured what...
2,290
I wrote a fairly basic program using full version of studio 5000 v30 that works well. Today I tried to add a few more rungs to control motor...
18
6,101
My company just purchased studio 5000 V30 for an upcoming project. I'm trying to decide how and where I want to handle the license key. Our...
3,342
Hi guys, I have a question I've been unable to answer with the available documentation and what I've got installed on my PC and readily at hand...
3,541
