Sensor for counting...
darrenj
Feb 2005
Ottawa
1,003
I am looking for sensor to "Count" product..Now before anyone jumps in and says use a photoeye..thats what we have..however its not accurate enough...
We are counting Milk bags Don't know if the people in states have seen them but they are tied the same way a loaf of bread is tied..the problem is when we view from the side the end of the bag (After the twist tie) catches the eye giving it a false count..Now if i put a time delay in to "debounce" we could miss the next bag if the spacing is off.. We run into similar problems going from above. It would also be nice if the sensor could tell if the bag was ripped and send perhaps a "reject" pulse or something along those lines...
I guess what i am thinking is a vision system..any other ideas (Cost effective!!) out there..
D
Is the eye viewing from the horizontal postion, and looking at a bag that is full and lieing on it's side, or standing up or what. It would seem to me that this would be simple with some mechanical engineering. Perhaps use a flow of air to direct the empty part of the bag that is not holding milk out of the way of the eye, or something to that effect. Get creative.
CroCop said:
Are you using diffuse or retroreflective?
Tried both..reflective for side viewing and diffuse for top..The problem with the diffuse is positioning..Its very finiky!..To close and it counts the conveyor to far and it misses the bag..just right..catches the tail of the bag..i end up with the same as a side view..
Yes its lying on its side..
Yes you are right it seems simple..However Nothing in life is easy!!
The air flow works to a point but not quite close enough...
They basically want balls on accurate..They either have bad counts or product going out the back door..before they go down the "back door" avenue they want to rule out 100% bad counts..
How bout you flip it?
Sense the conveyor, and monitor for a change outside of sensing the conveyor?
Or if you have analog, do the same with an ultrasonic.
hmmmm not quite sure what you mean..?
I can sense the conveyor but then how do i detect if a bag has passed under?
By using ultra sonic do you mean mesuring the distance from sensor to conveyor and then waiting for a change?
would i still not have the same problem with the tag end?
d
I assume the tage end still causes the sensor to change states, correct?
Does the signal go:
low high low high
conv bag tie end
The tag end has got to be a different signal from the conveyor (distance) so analog should read different enough to catch it.
Thats the problem..Look at a loaf of bread..the tag end is random..sometimes its higher than the bag..sometimes the same and sometimes lower..an air blast (Unless its a stupid amount of air) will sometimes not make a difference becouse of where the tag is placed..if its placed tight then there is more "frill" at the end..easy enough to push by air..If its tagged loose then there is not much frill..harder to push away by air..
you are correct the sensor on a perfect bag goes low high low high..however on a bag not tied..or tied a little off center the sensor stays high then low when there is no bag then back to high..this throws off the sequence of counts and realy buggers things up!
Then the analog (if it's capable of picking up the bag tie) should have enough play in it to smooth it out to one digital signal.
What about background suppression?
I have use the Banner Vision Systems for simular situations. I works great once it is setup, although I would have the factory rep show and demonstrate it. In certian situations it could possibly tell if the bag is ripped (depending on the color of the bag verses the milk. In US the price runs about $800-$1000, + what ever kind of light you would need. It will give you a count, although I am not sure what you are displaying the count on, but it does have Discrete outputs that you could possible use as well for the counter.
I used this on looking at lollipops to both determine if the stick was there and to make sure that the plastic was wrapped around the stick and not open. I my case I used the discrete outputs to tell good from bad and I kept track of the total count, via PLC and Operator Interface.
Try a light screen. For $350 you get 70mm detection height at 5mm resolution. Cheap and effective. Tried to post a link but it wouldn't work. Check out light screens at www.automationdirect.com
Item code: BX80B-1P-0H (pnp receiver-$190)or BX80B-1N-0H (npn receiver-$190). Plus you will need Item code: BX80S-10-0H (transmitter-$160).
You could use two screens to tell if the bag was torn also. Just set a second set higher than the first. If the first screen sees a bag but the second doesn't, then in all likelyhood it is torn.
Dale
i see what you mean but if i smooth out a midrange low that is actally a transition from one bag to the next i will screw up the whole count? The tag is also a problem now that you mention it..the ultrasonic..would it pick up the tag?? i guess it would...
BTW are you familiar with our "Bags" of milk??
D
Hi, I have a sensor that is FALSE when it is triggered, and a setup with boxes running past the sensor. I need to count how many boxes go past...
1,415
Hey All, I am looking for advice on the best prox sensor or device to use in this application. Customer wants to be able to count potatoes...
5,133
Hello everyone, We have can counting sensors on all our lines, i am sure all of us know why. So, one of our lines has started counting more cans...
3,282
Hi guys, I've an enquiry from our mechanical department to help source out a kind of sensor that is able to detect & count the nuts in a nuts...
41
8,473
Hi everyone, I am working with micro850, a proximity sensor (FOTEK, PL-05P) and a 3DOF serial arm robot. I use MC_MoveRelative to control the...
90
