RedLion Data Station Plus
josephem
Sep 2014
South Australia
I've been told to get the Red Lion Data Station to an Allen Bradley Compact Logix L32E. I want just basic comms established between the two but even that has been a struggle.
Here's what I have done:
1. In Crimson: I enabled network >> Protocol 1- AB L5K Tags : PLC1
2. Data Tags: I created a single tag (for simplicity) and selected source from PLC1 which I plan to record Tag1
3. Data Logger: basically left it all to default and Control: Tag : Tag1
I then pressed update (connected to RL Data Station via USB/PG)
After the CF light was steady I ejected took it to the AB PLC (connected PLC and RL Data station via Ethernet) and did a couple of runs.
I noticed Ethernet port wasnt blinking during the runs and when I connected the RL data station to my pc there was nothing in the CompactFlash
Any advice or Tips?
I'm definitely new to RL Data Station and still pretty green when it comes to PLCs.
What version of Crimson are you using? I am not familiar with the Data Station but when you set up your comms did you give the ethernet port a staic I.P. that mactches the network settings of the PLC you are wanting to communicate to?
Im using crimson 3.0 and yes both PLC and Data Station are on the same network with static IP's
My data station creates a csv but I dont think it is reading the values from the PLC since all my values are either off or zero.
Both my PLC and Data station are on the network because I could ping them both from my PC.
What kind of tag is it? Flag Tag , Numeric, Basic???
While connected to the DSP via USB, right click on the Data Tag and click "Add to Watch List". Then go to View --> Watch Window ---> Go Online . See if it displays a live value next to the tag name.
Hi jmaty23
Well I've put in tags or various types to identify if the tag type had to do with anything.
But I have been focusing on try to log a flag and a numeric
Just for grins and giggles, make a display page and plop a reference to the tag on the page. I have had one or two situations where I needed to display tags in order to get them to update contrary to other settings that should have had them updating anyway.
Can anyone help me getting this comms connection set up? I am using Port 2 on the Versamax ICU200UDR005-DK, set in SNP with port settings Baud...
1,572
Hi all, I am looking for someone that as some knowledge setting up a Redlion Data Station plus. I am looking to read a number of registers from...
2,270
Hi, I'm currently trying to connect a Redlion DSPSX to a Siemens S200 PLC. I can ping the S200 PLC and the DSP but I cannot get the two to talk...
4,437
I am polling 16 bit Integers from a Horner PLC and things work fine. I need 2 32 bit floats from the same device but I can't seem to get the right...
3,323
Hi, I have a complex database in Crimson 3.0 and in one of the display pages I am trying to get a tag to show the sum of several other tags. The...
180
