Danfoss Aquadrive FC202 - Local command only if no comm
Revnus
Aug 2019
Brazil
74
Hey guys.
As the title suggests, I need to configure a Danfoss Aquadrive FC202 inverter, so that its logic inhibits the local command when the PLC is communicating with the inverter. The inverter mode will always be “Auto ON”, never “Hand ON”, and operators will not have access to the inverter HMI. When "Auto ON" mode is selected, local commands (inverter inputs) have priority. But as I said, these commands should only be available if the inverter does not communicate with the PLC. I have no experience in Danfoss and I have 2 days to research how to configure this logic at Danfoss.
Any tips?
Thank you!
Hey guys, I got a PLC XBC-DR64H from LS i had a 32 points and switched for a 64 points. When i did my startup in my ladder im sending a start...
3,090
Hi all, We are currently experiencing an DC over voltage fault on one of our inverters. During commissioning a snag was raised whereby excess...
224
hey guys i've been trying to find an updated SW files of my danfoss fc360 for MCT 10 software but i couldnt be able to find it anywhere on...
262
Hello all. I am hoping someone here has installed a Danfoss VLT Midi FC 280 and connected an encoder to it. I am just trying to make sure I select...
474
Good morning! I'm trying to communicate a Micro 850 (2080-LC50-AWB) with a Danfoss FC202 by VLT 121 MCA Ehternet ip card. I can read the value...
461
