joseph_e2 Member J Join Date Dec 2010 Location Harrisonburg, VA Posts 1,102 Apr 25, 2024 #16 Gateways are fine if you need them, better to avoid if you can. Do you by chance have a Red Lion HMI or DSP or PTV in the system? If so, that can easily act as a gateway if it's within RS232 range of the field device.
tlf30 Lifetime Supporting Member Join Date Apr 2021 Location Deadhorse Alaska Posts 200 Apr 25, 2024 #17 joseph_e2 said: Will the Flex 5000 work with the L7x? I'm pretty sure the 5069 IO will not. Their client insists on an -L71. Click to expand... Yes, I think you are correct, my mistake. The 5000 series IO (Both FLEX and Compact) I believe are only L8xE controllers.
Sandsy90 Member S Join Date Apr 2024 Location Brisbane, QLD, Australia Posts 5 Apr 25, 2024 #18 Unfortunately this system isn’t using red lion, We don’t have have DSP or PTV within recommended serial distance.
