1756-EN2TR Ethernet Module - Change Subnet Mask
dalporto
Jun 2021
Montreal, QC
266
Hi. Rockwell learning curve 132-1b.
I was having trouble to change IP address on a EN2TR.
Finally found out that I need to change the IP offline, then online.
Still wasn't working until I figured that my mask was wrong.
I changed it online too and it's working now, but I feel that it should be set elsewhere that only online, right?
I cannot find it.
Thanks.
I cannot find it.
Thanks.
IIRC, the IP is device level. You set the IP at the device.
I cannot find it.
Thanks.
So for any ENxT, the IP is set at the device. The IP in the project can be completely different. The IP in the device can be set by BootP, Ethernet commissioner, RSLinx or Studio when online. Typically, the IP in the project is set the same offline and downloaded. But I've ran across many commissioned systems where the OEM/Integrator was lazy and didn't bother.
Hi All, Got a funny issue. I have a 1756-L85EP and a 1756-EN2TR in the same chase. The client asked for the Ferrari and the 3 lane highway!!! We...
224
Hello all, I have a 1756-EN2TR dual-port Ethernet IP Module attached to my 1756-L73 PLC. I currently have hazard symbols over both the top and...
170
I am using Allen Bradley PLC 1756-L81E and EIP module 1756-EN2TR for Ethernet/IP communication. My communication works fine but in Get-Attribute...
246
Good morning, I have a system on 1756 L73 that works with supervisor on EN2TR modules. Everything works correctly, except that EN2TR (1) with...
551
Hello Everyone, What is the best practice for DLR set up. Should I keep all VFDs on one DLR and FlexIO on another or it would make sense to put...
2,668
