Omron +CPM2C
wuestenfuxxx
Mar 2004
Hello!
I have to make a little adaptation on a machine,
which is controlled bei an Omron CPM2C PLC.
My problem is, that the program is password-protected,
which means i can't upload the program in my laptop.
Does the PLC lock itself after 10 false password entries,
like i heard it from another programmer?
Or exists a keyfinder or a simple trick, to unlock
the control?
Well
If the CPM is locked by password you canot open that. after 5 times
the PLC will lock and the only way to make any change is to erase the program and download the file again.even if you have the password.
If this is anything like Allen Bradley, there should be a default password that would work.
Kroz
Omron is not work like that.
If you made more then 5 treis the ony way to connect even you have the password is to download the file again.
They give you better system and more protected.
No shortcuts no bypass.
Hello, who can help me with my communication problem with Omron PLC. I have an Omron PLC (CPM2C-32CDT1C-D) and bought an communication cable, the...
3,080
i m just new to omron PLC,i wanted to establish a connection between pc and the PLC using CS1W-CN226 and a serial converter.but is there any...
1,608
I need help to program a CPM2C-20CDTC-D to drive a step motor and a air cylinder. The process is simple, but I have not done any ladder...
3,733
Dear all. We plan to use CPM2C for truckloading system. In 1 bay, we have 2 loading arm, we use 1 operator panel for one arm. Do you know...
1,873
F
HI guys, I would love to venture in to plc prgramming, and because i have no time for classes, i'm forced to do it on my own. I recently purchased...
2,164
