Rsstudio yellow ?
I'm working on getting some alarms on a panelview plus 1000 on our production line from a plc controlling the hydraulic pumps for this line. All are on the same network and I can see the lines slc505, the pvp and the L306ER in rslinx. When I go into rsstudio to make changes, I open the LinxEnterprise and go to the coms setup, add device. My processor has a yellow ? And I cannot add it to the shortcut. I'm running rsstudio ver7 ( crp9sr6) on a Windows xp machine. As this is out Scala machine with the backups on it. We also have a Windows 7 laptop that has the same version of studio on it but is running 64bit and it can see the L306ER fine. Only problem is if I change the program to work on the 64bit machine I can no longer use to xp machine where all our backups and programing is done from. Any help would be much appreciated.
Thank you all
Here is what I would try.
  • Unplug your network cable so FTV isn't trying to browse
  • Go to the Communication tab at the bottom of you project tree
  • Manually add a 1769 PLC instead of the 5069 to your Ethernet driver
  • Go to your communication setup, point your driver to the 1769 PLC
  • Copy form design to runtime
  • Plug in your network cable and test a screen
Attempted to import a module L5X to a project. The previous module occupying that Module name and IP Address has been deleted. Where would this...
2,287
About 2 years ago, I upgraded 6 workstations to Rockwell Rev 26.0. This included all the RsLinx, and RsNetworx, and rsView revisions that were...
2,114
Hi Everyone I am currently using an SLC0505 and Logix500 as house-control at my home. I want to upgrade to ControlLogix and Studio5000. Does...
18
3,604
How can I import my tags in 5000 into Studio? I see how to export them to a CSV, but studio wont read a CSV....help please???
3,957
I'm adding an IAI Gateway with 2 axes connected to it. To an ethernet network on my PLC. So, I think the math is correct on the Input and Output...
843
Top
