Write MSEC to S7 300 Siemens Controller
JAG
Apr 2023
Kansas
I am trying to write just MSEC to S7 300 Controller date/time using OI.SIDIRECT Aveva communication driver?
The old HMI (WINCC) tag is assigned to the address (DB905.DBD98).
New HMI: Wonderware Intouch 2023 Standalone application.
I have tried to use different canonical data types described in the SIDIRECT document to no avail. I have assigned a tag the following addresses:
1. DB905,TREAL98
2. DB905,DTL7,98
3. DB905,DTL98Byte7
** the second option halfway works. It performs the write but with a suffix of nanoseconds. For example when I write 2400, I get 2400.000000
Any suggestions would be greatly appreciated.
Thank you
Hi I have a ifix 5.5 application where the operator opens a valve by clicking on a screen object. I can trace from object to data base that it is...
43
Hi everyone, I hope you're all doing well. I'm currently working on updating an HMI project for the GP2500, and I've encountered a bit of a...
120
I've gotten to the learning curve where I can program a call for pump to come on at set point but I'm not sure how to turn the same pump off when...
144
Hi everyone, I am working on a project that needs to expose the SV (Set Value) of a temperature controller to a SCADA system. SCADA <-...
169
Thank you for any and all responses/help. I have an RSLogix 5000 v20 and a Cognex In-Sight v5.9 spreadsheet (8502P). I can not figure out how to...
142
