Wonderware Archestra Object Export Problems
iampatrick
Aug 2011
NC
When trying to export a template object, or the whole galaxy to a .aaPKG file, Archestra reports export completed immediately, with nothing else in the "Export Automation Object" dialog box and creates a 0kb .aaPKG file.
We are running Wonderware 10.1 and Application Server 3.1 SP3, on Windows Server 2008 R2.
Typically, before/after making any development changes to the application, I make a backup of the template, via object export to a .aaPKG file. This time, after a couple of days of development, the above problem is happening. I cannot export (backup) the latest version of the application. However, I have no problem checking the template in/out, making changes ect...
Furthermore, when I look at the Platform Manager, my GR Node shows "Shutdown (startup failed)."
I am inclined to reinstall the whole package, but I would lose days of work, without getting a real .aaPKG export.
Has anyone experienced this before? Any help would be greatly appreciated!
Here are the SMC Logs that occur when I try to start the platform. This machine does not have a Z:\ mapped.
210811735 10/28/2015 1:48:54 PM 2580 1740 Info GI22_GRNode.aaEngine Restoring the engine automation object from the checkpoint file ...
210811736 10/28/2015 1:48:54 PM 2580 1740 Error Resource Extractor2 CResourceExtractor2::GetPrimitiveDefinitionFromResourceId - CoCreateInstance failed. hr = 0x80040154
210811737 10/28/2015 1:48:54 PM 2580 1740 Error BaseRuntimeComponentServer INVALID HRESULT LINE 228 FILE Z:\AAMXCoreDev\src\BaseRuntimeComponentServer\CVS5DeploymentManager.cpp hResult 80040154
210811738 10/28/2015 1:48:54 PM 2580 1740 Warning BRO The run-time component -- CLSID = {5C3FCAFB-910C-44B4-BD95-BC6BDF9A8E9E} and Primitive id = 2 -- is not registered.
210811739 10/28/2015 1:48:54 PM 2580 1740 Error BaseRuntimeComponentServer INVALID HRESULT LINE 47 FILE Z:\AAMXCoreDev\src\BaseRuntimeComponentServer\CDeploymentPrimitive.cpp hResult 80040154
210811740 10/28/2015 1:48:54 PM 2580 1740 Error BaseRuntimeComponentServer INVALID HRESULT LINE 452 FILE Z:\AAMXCoreDev\src\BaseRuntimeComponentServer\CDeploymentPrimitive.cpp hResult 80040154
210811741 10/28/2015 1:48:54 PM 2580 1740 Error BaseRuntimeComponentServer INVARIANT FAILED LINE 3536 FILE Z:\AAMXCoreDev\src\BaseRuntimeComponentServer\CBaseRuntimeObject.cpp LAST ERROR 0
210811742 10/28/2015 1:48:54 PM 2580 1740 Error BaseRuntimeComponentServer INVARIANT FAILED LINE 3536 FILE Z:\AAMXCoreDev\src\BaseRuntimeComponentServer\CBaseRuntimeObject.cpp LAST ERROR 0
210811743 10/28/2015 1:48:54 PM 2580 1740 Error BaseRuntimeComponentServer INVARIANT FAILED LINE 3536 FILE Z:\AAMXCoreDev\src\BaseRuntimeComponentServer\CBaseRuntimeObject.cpp LAST ERROR 0
210811744 10/28/2015 1:48:54 PM 2580 1740 Error BaseRuntimeComponentServer INVARIANT FAILED LINE 3536 FILE Z:\AAMXCoreDev\src\BaseRuntimeComponentServer\CBaseRuntimeObject.cpp LAST ERROR 0
210811745 10/28/2015 1:48:54 PM 2580 1740 Error BaseRuntimeComponentServer INVARIANT FAILED LINE 3536 FILE Z:\AAMXCoreDev\src\BaseRuntimeComponentServer\CBaseRuntimeObject.cpp LAST ERROR 0
210811746 10/28/2015 1:48:54 PM 2580 1740 Error BaseRuntimeComponentServer INVARIANT FAILED LINE 3536 FILE Z:\AAMXCoreDev\src\BaseRuntimeComponentServer\CBaseRuntimeObject.cpp LAST ERROR 0
210811747 10/28/2015 1:48:54 PM 2580 1740 Error BaseRuntimeComponentServer INVARIANT FAILED LINE 3536 FILE Z:\AAMXCoreDev\src\BaseRuntimeComponentServer\CBaseRuntimeObject.cpp LAST ERROR 0
210811748 10/28/2015 1:48:54 PM 2580 1740 Error BaseRuntimeComponentServer INVARIANT FAILED LINE 3536 FILE Z:\AAMXCoreDev\src\BaseRuntimeComponentServer\CBaseRuntimeObject.cpp LAST ERROR 0
210811749 10/28/2015 1:48:54 PM 2580 1740 Error GI22_GRNode.aaEngine From ObjectResources2.ResourceExtractor2.1. Unable to CoCreate DesignServer component. Unknown error 0xC0000005 (c0000005) raised.
210811750 10/28/2015 1:48:54 PM 2580 1740 Error BRO GI22_GRNode - CBaseRuntimeObject::SystemSetAttribute - Caught unknown exception.
210811751 10/28/2015 1:48:54 PM 2580 1740 Info GI22_GRNode.aaEngine Starting up the engine automation object ...
210811752 10/28/2015 1:48:54 PM 2580 1740 Error BaseRuntimeComponentServer INVARIANT FAILED LINE 687 FILE Z:\AAMXCoreDev\src\BaseRuntimeComponentServer\CBaseRuntimeObject.cpp LAST ERROR 0
210811753 10/28/2015 1:48:54 PM 2580 1740 Error BaseRuntimeComponentServer INVARIANT FAILED LINE 687 FILE Z:\AAMXCoreDev\src\BaseRuntimeComponentServer\CBaseRuntimeObject.cpp LAST ERROR 0
210811754 10/28/2015 1:48:54 PM 2580 1740 Error BaseRuntimeComponentServer INVARIANT FAILED LINE 687 FILE Z:\AAMXCoreDev\src\BaseRuntimeComponentServer\CBaseRuntimeObject.cpp LAST ERROR 0
210811755 10/28/2015 1:48:54 PM 2580 1740 Error BaseRuntimeComponentServer INVARIANT FAILED LINE 687 FILE Z:\AAMXCoreDev\src\BaseRuntimeComponentServer\CBaseRuntimeObject.cpp LAST ERROR 0
210811756 10/28/2015 1:48:54 PM 2580 1740 Error BaseRuntimeComponentServer INVARIANT FAILED LINE 687 FILE Z:\AAMXCoreDev\src\BaseRuntimeComponentServer\CBaseRuntimeObject.cpp LAST ERROR 0
210811757 10/28/2015 1:48:54 PM 2580 1740 Error BaseRuntimeComponentServer INVARIANT FAILED LINE 687 FILE Z:\AAMXCoreDev\src\BaseRuntimeComponentServer\CBaseRuntimeObject.cpp LAST ERROR 0
210811758 10/28/2015 1:48:54 PM 2580 1740 Error BaseRuntimeComponentServer INVARIANT FAILED LINE 687 FILE Z:\AAMXCoreDev\src\BaseRuntimeComponentServer\CBaseRuntimeObject.cpp LAST ERROR 0
210811759 10/28/2015 1:48:54 PM 2580 1740 Error BaseRuntimeComponentServer INVARIANT FAILED LINE 687 FILE Z:\AAMXCoreDev\src\BaseRuntimeComponentServer\CBaseRuntimeObject.cpp LAST ERROR 0
210811760 10/28/2015 1:48:55 PM 2580 1740 Error GI22_GRNode.aaEngine Could not perform operation -- unexpected exception. Unexpected failure (8000ffff) caught at line 238 in FsEngine.cpp (in Z:\SysObjectDev\src\FsEngine\).
210811761 10/28/2015 1:48:55 PM 2580 1740 Error GI22_GRNode.aaEngine WinMain exiting error code 8000ffff
[FONT=&quot]210811762 10/28/2015 1:48:55 PM 2580 1740 Info GI22_GRNode.aaEngine Exiting process "aaEngine"[/FONT]
I have created a PID object in Archestra. I have derived a template from User Defined Template. I have defined all PID parameters as field...
2,477
Hi All I'm a novice starting to work on WW and Archestra, I've been adding repetitive attributes on the front end which has been tedious and was...
2,121
Hey I was needing help with some alarm scripting in Woderware System Platform. What would be the best way to write a script to auto acknowledge...
2,572
I am trying to create a script in an Archestra graphic that will eventually talk to an Omron PLC. I need to access the elements that I create for...
1,629
The application is not getting deployed after a power failure. After the power got restored, I tried to deploy an updated instance but the...
4,061
