where to start with Siemens S7-200 CPU-226
diat150
Mar 2006
Louisiana
1,474
Its a S7-200 part # 6ES7 216-2BD23-0XB0
A customer sent me one of these to extract the program out of. I have zero experience with Siemens S7 line and need help determining which software I should use and if I need a special cable or can I use a regular straight thru serial cable or with a null modem. It has 2 DB9 connectors labeled port 0 and port 1.
Any help would be much appreciated
Step7 Microwin for programming and a PPI cable for download/upload.
If you extract the program from the CPU itself, you'll loose symbolic names and comments..
You will need Microwin software:
6ES7810-2CC03-0YX3
STEP7-MICRO/WIN V4.0 (UG) G/E/F/I/S/C
A pc adapter capable of comunicating with PPI:
6ES7901-3CB30-0XA0
SIMATIC S7-200, PC/PPI CABLE MM
Or usb version
6ES7901-3DB30-0XA0
SIMATIC S7-200,USB/PPI CABLE MM
There are also Adapters that can handle PPI/MPI and Profibus.
For 200/300/400 series:
6ES7972-0CB20-0XA0
SIMATIC S7, PC ADAPTER USB
First check to see if there is a CN on the end of the part number... Siemens does not make the 200 anymore so if it has a CN on the end its a China made one... Siemens China is still making the 200 smart series for China and India
We sell a MultiMaster cable that supports all baud rates and I would recommend that cable as I have never had one it will not work with
https://www.plccable.com/siemens-usb-ppi-multi-master-187-5k-6es7-901-3db30-0xa0/
For the software, if its a US/EU CPU than try contacting your local Siemens distributor, they gave me my first version of MicroWin, the last version was V4.0 SP9
I am currently enrolled in a 3-year technical program at a collegiate institution. This is my last year. I also work in a co-op fashion for an...
4,716
I am currently a senior in a vocational school, for the past year I’ve been working on RSLogix and really found a passion for it. I want to become...
1,918
I've been doing control systems design and PLC/HMI programming for about 3 years at my current company and I've really come to love it. However...
17
4,199
Hi all, noobie here to plctalk! I currently work as a robot programmer/operator, I program a ABB IRC5.15 linishing/polishing robot and a CLOOS...
3,442
I have recently been tasked at a new job to integrate all the automated cells at our plant to have remote access to the production data (viewing...
18
5,493
