When Does a Control Panel Become a MCC?
northwind
Jan 2007
NH
If building a control panel in a 508a shop, when does it become a motor control center and fall out of scope for labelling under 508a?
More specifically; a large floor standing control with a multi-section cabinet. First section has incoming main breaker (>/= 1,000A with LSIG protection), remaining sections have breakers for process loads under PLC control. Each section has a breaker (or breakers) and typically a VFD or two. Feed from main to sub breakers could either be via power distribution block and individual cables, or possibly a pre engineered buss system.
The distribution sections would be touch safe wiring with external operators on the branch breakers and isolation barriers.
I don't see a problem with labelling this Under the scope of 508a, the main can even be a service disconnect (under section 73). When does this cross the line into being a UL845 MCC? Field removable "buckets"?
Thanks.
I currently have a setup in Siemens S7 using I-Device connections over PROFINET and I am trying to investigate an equivalent setup using Rockwell...
1,141
Whenever I try and change display pages on my Panelview Plus 7 from the remote display change the screen errors out like it has a communication...
1,513
Plant PLC has no reasonable stop start sequencer. There is 3 states, Available, Start & Stop. A 10 sec timer exists in the Stop Ladder that is...
2,720
Hello. I have a system in which I have only installed the CODESYS Control Win x64 package, without the development environment. I have one issue...
2,753
Can someone help me because my Adodc is not communicating to my SQL pack? 1 - My factorytalk 8.0 when I fetched the Object - Active Control -...
1,176
