Vijeo designer 6.2
mr.qrsa
Apr 2024
south africa
Good Day all.
I am currently busy with a schneider HMI design in vijeo designer and i want to know how you can animate an image to move on the x and y axis is there anyone who can assist me it is not as easy as on TIA portal?
if anyone has done it before can you please put up a picture or two of how you have done it there is no complex vijeo tutorials on YouTube.
thanks.
hi,
First, in the animation properties, set x, y variable for positions. Then under the panel in that the image locates, create a panel action -> trigger type = periodic, set enable condition and, for best performance, frequency = 0.1. Next, create procedures to increase/decrease x, y variables.
The pic is a sin wave animation I built.
You can also use script to do the procedures as well.
hi,
Thank you i am getting there but can you maybe give me some more step by step examples i did a 4 way traffic light system and are trying to make a vehicle image run accross the hmi
Hello, I have been tasked with adding some analog signals for display and alarm setup in some old Schneider Electric HMIGTO HMI-panels. I have...
201
Since upgrading to V6.2 12.24 SP12 24-21 the M221 PLC is no longer recognised by the HMI. The screen still works but it does not talk with the...
1,014
I work for an OEM. I am trying to develop a generic HMI program that will display an overview screen displaying between 2 and 6 "widgets"...
1,335
Hey all, I am using Vijeo Designer v6.2.8.12 for a mineral plant project. For that, I needed to incorporate three different plants' HMI page in...
1,210
Hi, Is there a way to get an alarm ack/active flag in Vijeo Designer to store in a internal var? I found under action there are alarms action you...
1,465
