Vijeo Citect 7.4 Super Genie
chud
Oct 2007
KALAHARI
1,123
Hi Guys
1st Project with Vijeo Citect and I am stuck with a simple problem opening a popup from a motor.
I used the Assmetadatapopup("spage") function on the motor, and assigned all the tags for the popup in the metadata tab.
But whenever I click on the motor genie to open the super genie popup it gives a message at the bottom left of the runtime saying it cannot open the page I am trying to open...
Is there any extra cicode needed with the assmetadatapopup function?
Thanks for any help
Hello Everyone, I'm editing an existing Vijeo Citect project and it is my first time to use this software. I created a super genie and used a...
3,494
Hello, the system we use is Scada 7.5 series. We have usb key activ now we need additional key to make the system work, how do we solve this...
86
My system are taking data from RHT sensors, around 45 points. Now I want to make a function in which, if the data is #BAD or 0 in values for all...
494
I have DI module ICPCon M7024UD connect to my pc using COM3 MODBUS RTU and also RHT sensors are using MODBUS TCPIP.. The problem is, it cannot...
1,705
I need help with vijeo citect 7.4 as I use Modbus TCPIP to get the data, it turns out the address is having error.. For example, when I write...
907
