use Simotion D ethernet port as gate to access S7-1500 plc program
Kataeb
Jan 2007
www.livelovelebanon.com
636
Can we use a Simotion D455 ethernet port x127 as a gate, to access S7-1500 plc Tia Portal program ?
In the Simatic manager, we used Netpro to do the settings, and it worked well.
What is the procedure in the new Tia Portal?
Just network or connect the ports
And add a subnet to where your pg will connect.
It routes the same way Startdrive would route to drives
I also assume your 1500 and D455 are in the same project
Let us know how it goes
See the FAQs below for setting up and using S7 routing between projects
Hi, guys, how’s going? We get one SIMOTION D435 machine. The communication between D435, PLC and HMI is built by Ethernet cable. (D435 IP...
4,926
We currently have a a Siemens simotion "6AU1 230-2AA00-0AA0" controller, this is connected via ethernet to our scada system, The system works and...
1,782
Hello everybody, I'm currently working on a project where I need to implement an IoT platform based on Microsoft Azure Cloud. Communication is...
72
Hello everyone! I'm currently working with SIMOTION D410-2 with a CF Card labeled with SIMOTION D410-2 V5.3 SP1 HF9 + SINAMICS V5.2 HF6 From...
529
Hi, I have a program that is mainly coded with Italian comments. I want to find a way to export all the comments and then run them through google...
1,335
