USB rfid reader/writer
dwoodlock
Nov 2012
Cincy Area
573
Looking to see if someone can suggest one of these for me, something ideally compact, and not insanely expensive. I'll end up buying probably 4 of them.
We are using baluff's as our main write/read heads, but I would like something I can plug into a desktop.
The EPC Gen2 tags make it fairly easy because they are probably the most popular. I have only personally used Ethernet readers for Gen2 tags, so I do not have any personal experience with USB versions.
Do you need a reader/antenna combo like this:
https://www.amazon.com/RFID-ME-USB-Dongle-Reader/dp/B0050MBFE8
Or do you need a USB reader with the ability to connect a remote antenna? Or even possibly a handheld scanner like this:
https://www.barcodesinc.com/motorola/part-ds9808-sr7c1u16ar.htm#specs
Archie, this is the sequence that I am planning to implement.
  • 1. Batch#/Date/Part# are stored on the tag, and then basket is loaded onto a que conveyor for the next process.
    2. Basket is processed.
    3. Basket exits onto another conveyor and reaches a checkpoint.
    4. Operator reads RFID information and interfaces with a computer for print a new router card.
    5. Parts are moved to a new container.
    6. Operator uses the "device" to write a generic value to the tag which system wide identifies an empty basket.
I am hoping to find something similar to a barcode reader that's for RFID's and can also write to tags.
Just an update
I spoke with the programmer today about the process flow today, and he was able to help clear up exactly what I needed to do. Tags are only written when loading into the system, and if the basket hasn't gone through that sequence the tag data remains until it has.
We are making a really smart dumb conveyor with a 1200, and trying to keep within the memory constraints can be a doozie.
I ordered a couple Alien Technology ALR-H450 hand scanners today.
Hi everyone, I have been having some trouble with a project I am currently working on. The end user will have an RFID fob, which they swipe, and...
4,137
Looking for recommendations for USB-C to serial adapters. Mainly used to connect to SLC and PLC5 processors.
183
Anyone know of a cheap foundation fieldbus communicator? Something like the USB 8486 H1, but one that does not cost $3k? Thanks, Trevor EDIT: I...
135
please using the usb can i assign any ip address that i want ?
159
Dear all, I have fx3u series plc with built in rs422 port and usb-sc09-fx cable. I have a a hyperterminal like application to send and receive...
244
