Unwanted Messages on Panelview Plus 6
Compass
Feb 2015
Goderich
101
Hello,
Every 5 seconds the following message flashes on the center of a panelview 6 1500 screen:
MERuntime 12992 KB
Total Ram Usage 44860 KB
Available Ram 395148 KB
I'm guessing it's not an alarm, since we have plenty of Ram. How do I turn this off.
Did this just start happening? If you open the program in View ME, Is there a popup display setup w/ this information set to open?
Edit: https://rockwellautomation.custhelp.com/app/answers/detail/a_id/51831
According to the technote,
"Problem
The PanelView Plus is showing runtime RAM usage at runtime. It is a small white box in the center of the screen that intermittently keeps popping up displaying RAM information.
Cause
The Show Ram Usage option is set to Yes on the HMI.
Solution
On the PanelView Plus Configuration screen go to Terminal Settings -> System Information -> Terminal Information -> Runtime RAM Usage.
Set this option to No."
I recently discovered that when downloading an online edit [S7-1500] that requires the initialization of the modified FB's iDB, an IEC timer whose...
36
11,956
so im trying to figure out a way around a little dilemma here with an RFID reader. I have older logic from another setup that works with all of...
2,896
Hi I use from Delta PLC and I use from EN01 module for communication I assign an IP address to it statically. But I have problem.this IP after a...
2,524
Hi, I'm doing a new year clean out and have a ton of hardware here I ll never use. Slc CPUs, racks and I/o modules, wago Plcs and IO, Siemens S7...
9,045
Good day all. I have a situation with a program that I can't find the root cause. I have a conductive level sensor that that is supposed to be a...
2,247
