ultra 3000i
Welcome to the forum.
please explain in more detail what you have.
Model # of the drive, part # of the cable, software and version you have.
what steps did you do to try and get communications established?
regards,
james
Hello
Which software are you using. Ultraware or Ultramaster.
"The Ultra3000 includes a mechanism for restoring serial
communications, in case the drive has unknown serial interface
settings or communications cannot be established.
For the first 3 seconds after reset or power-up, the drive listens for
messages with the following serial interface settings."
Baud Rate 9,600
Frame Format 8 data, No Parity, One Stop
Drive Address 254
Hope This Helps
Tom
My servo motor MPL-B330P-S is controlled by an Ultra 3000i. The problem is that the active position is always different from position command...
1,196
Hi All, I having some problems setting up a new drive using Ultraware. The application is a simple bucket conveyor that indexes along each time...
2,377
I have two AB ultra 3000i servos (2098-DSD-020X/C) with a 3-wire null modem to the PC using Ultraware Version 1.80.0.0 in Tools->Recover...
2,615
Software: Ultraware 1.64 Hardware: AB Ultra 3000i This will be my first go at tinkering with a servo and ultraware so I thought I should get some...
4,228
Hello all, We have Error 77 being displayed on the devicenet module. We have been looking into this thread...
2,800
