TIA portal where did reference data go?
adamplc
Dec 2009
usa
92
I'm having a tough time trying to get used to old habbits in S7 and them not being the same in TIA portal. First impressions are its cr*p what were they thinking. Anyway how do you find out available memory bytes? I used to go to reference data in s7 and the list was right there. So if there is no reference data in TIA how do you find unused memory bytes?
Thanks for any help on this.
My next question how can you have more than 1 project open at the same time, I need to import functions from another project but see no import or any way to do this.
Start TIA V11 twice - it is possible to have two instances of portal running at the same time.
now this is not working
This is strange, why does this not work mw210 stays at zero even after the pulse of i1.0 used to work in s7, but if I use the other coil pulse it works.
I am using a 1200 series plc
Carefully read the help on these instructions and try to understand how they work. They are a bit different than in the classic S7; also there are some new instructions for edge detection.
TIA Portal V13 SP1 - first impressions I've spent some time playing with TIA portal v13 over the last few weeks and on the whole, I like it. I...
4,597
Hello, good morning, I have been having two problems with the Tia Portal software. The first is that I have installed it on my computer and...
75
Hello all! So I have one project with a S7-1214 and a MTP1500 "Project1" and one project with another S7-1214 "Project2". Both of these PLC:s need...
87
Hello, i am using profibus as communication between plc and fanuc arm. I can easily send inputs from plc to arm, but i can't monitor any outputs...
39
Hello, I need to write the following program in Ladder language, but I could not integrate the Fibonacci sequence into the ladder. Can you help...
22
455
