TIA Portal pop-up display like it is implemented in FTV?
h4rdw4re
Jul 2017
Lukavac
Hi to all,
Does TIA portal support creating reusable pop-up display as FTV has it implemented?
Something like on link below.
Thanks in advance.
what device are you using ?
If you have basic hmi panels you can't do anything like that.
If you have comfort panels, runtime advanced or unified panels you can create "faceplate"
In the TIA project, browse to Screen management .. Pop-up screens.
I dont know the pop-up screens in FTV. If these can use parameters being passed in and out of the pop-up, then maybe the more similar object in TIA is the Faceplate object.
Hello, I'm looking for the best way to have different data displayed on a pop-up based on an index number. For example: Imagine that I have 10...
7,939
Hi PLC people, think about this scenario: The PLC is somehow connected to the same network with the facilities` network. Then someone connects to...
93
Hello, good morning, I have been having two problems with the Tia Portal software. The first is that I have installed it on my computer and...
194
Hello all! So I have one project with a S7-1214 and a MTP1500 "Project1" and one project with another S7-1214 "Project2". Both of these PLC:s need...
118
Hello, i am using profibus as communication between plc and fanuc arm. I can easily send inputs from plc to arm, but i can't monitor any outputs...
48
