Temperature/Humidity Sensor Ethernet/IP
owenjoo
Mar 2024
Wisconsin
I am looking for temperature/humidity sensor recommendations.
Would like the sensor to display temp and humidity.
Need to connect to a Contrologix PLC via ethernet/ip.
Will be historizing the data through Wonderware.
Does such a sensor exist?
I know there are analog sensors available but I really don't want to add an analog module.
We have used this sensor from IFM on I/O link LDH292. They also a LDH290 which i think is analog.
  • LDH292-00_EN-GB.pdf
  • LDH290-00_EN-GB.pdf
Greetings, I've done some basic web searching and haven't been able to find what I'm looking for. I'm looking for a basic Temperature/Humidity...
10,213
Hi, I've a project require 12 humidity sensor located in indoor. Anyone can recommend? Can this humidity sensor direct wired to PLC Input (mA...
11,288
I am looking for an inexpensive temperature and humidity transmitter. Evironment is not harsh (people work in this area.) I have used Vasalia in...
4,338
Does anyone know of a sensor/transmitter that is able measure humidity/dewpoint/water concentration in a stream of 1200F air?
3,441
Hello, Has anyone developed the relative humidity value by a temperature thermocouple? I also have pressure values. I have seen some formulas to...
1,989
