"Swapping" safety relays, question about the wiring changes (if any)
DzL9
Oct 2023
Louisville, KY
Hey guys, the scenario is: I have already completed the drawing package for my system utilizing an A-B 440R-N23126 (Minotaur) safety relay. SoS decided that we go with a cheaper relay... the IDEM SCR21-280001. The system has 2 dual-channel estops that need to be auto-reset. No other safety devices.
I'm not super well versed in these safety devices... I can see that it doesn't appear the two relays are exactly the same in terms of their internal operation, and thus are most likely wired a bit differently. (As in, more than just re-naming terminal labels). Attached is what I have already drawn, and also the wiring diagram supplied with the new IDEM relay. Could someone shine some light as to what wires need to be moved to where? I'm having a hard time discerning the differences. Thanks in advance, you guys rock.
I just finished a project that was using a CompactLogix(5069-L310ER2)and the project now requires a GuardLogix(5069-L310ERS2). I will be...
645
I had a processor go out on a PLC rack. I am trying to use a different processor because that is what the customer had available. Original was...
1,264
I need to swap out a compact logix 1769-OB16 does the firmware and the series have to match with the new one. Can I upgrade or downgrade the...
1,097
Hi, Looking at installing a L8x redundancy system and have perused the manual. Yep version 1 (beta..) on L8x, probably not the best idea, as well...
1,433
Hi. I have been tasked to update a plc project for my work. Currently, the project is controllogix platform and controlling several drives. The...
1,677
