Stratix 5700 vs Studio 5000
Chibu
Feb 2023
Ontario
49
Hello,
I added Stratix 5700 switch (rev13.001) to Studio5000 (rev 33.02.00) as Ethernet Module but it shows mismatch/yellow triangle on the module in the Project tree.
I can't access the module properties online.
I have downloaded the appropriate AOP yet no luck.
Any ideas?
Can you logon the Stratix web server and confirm the actual firmware version of the Stratix and confirm that what you are trying to configure corresponds to the actual device?
When you go to the module info tab of the stratix 5700 when online in Studio, what does it tell you? It will usually show the reason for the mismatch. Either that or if the module info tab shows nothing, then the stratix isn't communicating to the processor. From your PC, open a cmd window and see if you can ping both IPs of the PLC and stratix.
When Online, if I try to open the module properties, the Studio5000 freezes up endlessly that I will have to restart my PC.
Hi Folks! Could I use the Studio 5000 to read/monitoring Stratix 5700 parameters? Like switch temperature for example
394
Kindly, if we enable the routing on the Rockwell Stratix 5700 switch, as in the below link, will it cause any trouble? Like for axis motion...
164
Hi Guys, I have a Stratix 5700 managed switch that will connected to another different network thus: Stratix 1 on 10.50.3.xx >connect through...
128
Hi All, I've been playing with 2 stratix switches in my test bench and seeing how different configurations affect the behaviour when 2 managed...
241
Hi All, Have a question about setting up routing across VLANS. I have attached a picture of the layout and will try describe best I can...
720
