Step7 Copy string in FB IN_OUT UDT var
jenzop
Mar 2024
spain
Hello
Inside a FB, I´m trying to transfer a string from a DB to a IN_OUT var that was define as a UDT.
The problem is that i can´t determine the adress .
I need to transfer a string[19] from a DB to OP.AuxDatos.AuxDatoVacio.InicioCiclo
do some research on pointers, also known as P# - you will be working with indirect addressing. To find the location (or address) you can open the instance DB (or IDB) of the FB call and read your column markers. You can also identify the location directly from the instance tables you show above, but you have to click through the layers of the data structure and add them together.
If I open the DB of instance the I_O section only appear UDT row, with 4 bytes.
But the UDT have 366 bytes
Is your FB call up to date? Did you modify the UDT (increase it's size from the original 6 bytes) after doing the initial UDT call as an in_out?
Hi Im trying to use SFC20 BLK Move in a piece of SCL code in Step7. I need to copy/move one string[16] in a DB to another DB place ! If a block...
13,512
There must be a way to create a 'String Copy' function in Step7, something like: Call FCx FromStr:=SourceString ToStr:=DestString or am I...
5,192
Hello! Is it possible to copy pointer's pointing address to any variable at Siemens step7? I mean I have pointer address to db block with...
15,582
Hello. I need your help. I work at STEP7. There are two CPU 317-2 PN/DP controllers (317-2EK14-0AB0), working on PROFIBUS, as Master (CPU_1) and...
45
This is the first time I am working with Simatic Manager Step7 as I started my siemens journey with TIA which is pretty easy and do a lot of stuff...
165
