Square D Symax model 50
cdisher
Oct 2002
Northern Indiana
32
Today I was asked to asked to help the maintenence people get one of the machines up and running again. I have been retired 8 years and had not worked with this controller for some time. The programming cable had broken conductors and was replaced with a new one from Sq. D. We are getting communications timeout messages along with protocol error 1028 messages. I have checked the port assignment, baud rate, drop number, memory size and still no communications. It appears to transfer the program but there is nothing there. When you try to go to run mode, you get communications timeout. The hand held programmer will load simple program and the processor will go into the run mode. I am beginning to suspicion the new cable. Am I overlooking something? This is the old DOS software. Thanks in advance.
The Model 50 software does not communicate reliably on computers faster than 15-25Mhz. You need to run a program that will effectively slow down your computer. In the old days I used SLODOS although there are/were other freeware programs available.
I remember the Model 50 was programmed with RS422. Check your cabling.
This unit is the same as a Idec FA1J, but I think Square D put a different EPROM in it to work with their software.
Square-D Symax SFI-324 I have used the SFI-510 card for many projects, but I came across a SFI-324. Does anyone have ant tech info on it?
86
Hi, We are getting an intermittent 20001 error on our old SquareD PLC. It has 3 remote racks in close proximity and every few hours seems to drop...
1,943
Hi, I am currently developing a HMI to replace an old screen that is no longer available to purchase. The plan is to connect the panel view to...
2,312
ok gentlemen i have a question. I am working on converting some old square d logic to allen bradley. my question involves the MARK bits. i...
1,879
Please tell me what type of Card this Is Class 8038 (might be 8030) Type ROM 431 Regards Ian T
2,596
