SimoReg DC master Siemens Drive upgrade
a7med918
Dec 2007
cairo
46
Dears
kindly need support to replace old SimoReg DC master Siemens Drive and upgrade to sinamics 6RA8081-6DV62-0AA0 series
communication is profibus and PLC system is CPU414-2DP with step7-V5.6 SP1 software and what i need is
1- PLC HW configuration upgrade to new drive.
2- PLC software modification (if needed) specially in status control word as i cant find any data regarding old drive.
3-any wiring that must rewiring in new drive.
and what i know and already have now is:-
1- old drive parameter
2-PLC application
3-Drive address (P918)
4-all old drive wiring and encoder wiring
5-Old drive type is 6RA7078-6DV62-0
6-New drive type sinamics 6RA8081-6DV62-0AA0
Does your 6RA70 use standard ppo type?
Which one?
You have to make sure everything is lined up from one drive type to the other
Which one?
Dear Sir
Thanx for your reply
kindly find data regarding old drive 6RA70
PPO4: 0PKW , 6 PZD
> PPO4: 0PKW , 6PZD i ADDRESS 688...699 , Q ADDRESS 688...699
How can i line up old data in new drive?
I looked over it but I dont have the time to put in it
I recommend the op hire someone
Start off by comparing a default drive set with your dnl file
Hi, I'm trying to set up a Siemens Simoreg DC-Master on devicenet without using explicit messaging. I can't figure out exactly how the eds file...
5,887
Hi Can someone please tell me where I can find information about the heat developent / dissipation of a Simoreg DC Master? 📚 The information...
946
Hello everyone. I wish you a good day. I have an S7-300 PLC with my Simoreg DC Master device. Simoreg My device code: "Siemens DC Converter...
2,050
Hello friends. My 6RA7078 Type Simoreg driver to the machine It sends an error "Continuous loop without Static Activation". The fault I...
1,367
Please help if anyone can. I must first state that I do not have any sort of vast electronic knowledge. I am a plant manager looking for answers...
85
28,661
