Siemens S7/TIA v16: Extended Download to Device...
Mas01
Oct 2020
Leicester, England
1,109
I'm new to S7.
Whenever I do a "Download to device", this window appears.
I've seen some online tutorials and this doesn't happen for them, so my setup must be different somehow. Not sure why this is the case, but presumably, I click YES to this prompt.
picture to follow...
I think this is more of an IT issue than a Siemens one. This happens to me a lot because where my automation gear is connected to the company network it uses a different subnet to everything else. As soon as I drop an online connection within 30 seconds the network settings on the computer revert to the other subnet.
I have found that after too many of these prompts it can sometimes just say unable to connect, so you have to either manually change the network adapter settings or restart the computer.
In OB1, I'm monitoring some values (first pic). The values are what I expect. At the same time, I'm monitoring the same values in the DB where...
680
Siemens S7/TIA v16: "Overwrite if object exists online?" HMI loading message... Thus far, I've just been ticking this box, just to get the HMI...
804
I'm having a bad day. Daft question coming up...Anyone know why I can't add anything into this DB? Add button is greyed-out. Thanks
1,646
I imported a customised shape into the project, but I don't know how to actually add into on to a specific HMI screen. Do I use the Graphics menu...
682
Hi I'm trying to display a value on the HMI. In monitor mode on the code, I can see that value, but on the HMI , after downloading, it is...
982
