Siemens S7-1200 firmware upgrade
goghie
Jan 2008
Belgrade
802
Hi Experts,
I would like to make firmware upgrade from v3.0 to v4.5 (S7-1200 CPU 1215C).
Can I do it from v3.0 to v4.5?
Do I need to take some special care?
Thank you.
Best regards.
What is the PLC part number? If I do a version 4 firmware upgrade it tells me that it only applies for version 4 or higher, so I don't think it can be done.
6ES7 215-1AG40-0XB0, that is a version 4, not sure you got version v3.0 firmware on to it. As for anything to watch out for, touch wood, had no problems, except maybe finding the firmware on the Siemens website :). To upgrade, I go to Online and Diagnostic and once online choose firmware upgrade, point it a the unzipped file that I downloaded, and leave the software to get on with it. I have tried to put the wrong firmware on to the wrong PLC and it did stop me.
I think going from v3.x to v4.x is not possible.
Here's a note from a Siemens article/FAQ.
What should you watch out for in STEP 7 (TIA Portal) when replacing an S7-1200 V3 with an S7-1200 V4?
  • Entry
  • Associated product(s)
Note
A firmware upgrade of the S7-1200 CPU modules is possible only from V.1x to V2.x. It is not possible to make a firmware upgrade from V2.x to V3.x nor from V3.x to V4.x. The firmware V2, V3 and V4 each require corresponding CPU hardware.
Question for the Siemens gurus here. We have one stand-alone piece of equipment that is running an S7-1200 processor. The manufacturer has...
2,432
Hi folks, Just doing a project where we are having to get bits of data from various plcs (get & Puts etc) and adding a CP module into the mix...
1,831
I have a customer that has a failed 1200, they are getting a replacement from me its a 6ES7212-1AE40-0XB0, his original has FS02 and the new one...
1,953
Hay eveybody, I heared few days ago about Siemens S7-1200 fw v 2.0 and it will support web-server technology . I am about ordering S7-1200,CPU...
10,397
Hi all, Currently having trouble getting a speed reference to write over modbus to an Omron M1... I can successfully write a run command and...
286
