Siemens RTM instruction
The S7-1200 CPU operates ten RTMs (Run-Time hour Meters). The NR input parameter to the RTM instruction determines which of those ten that instruction uses. Since the value of NR is the same, i.e. 0, on all of the RTM instructions in the program, the CPU uses the same, i.e. only one, run-time hour meter for all of those instructions.
So when you wrote "I have more than one RTM in my program," you should have written "I have only one RTM in my program" instead.
The PLC cares not a whit what we want it to do, but it will mercilessly and inexorably do exactly what we tell it to do.
The only thing worse than the PLC not doing what we want it to do is when it does exactly what we tell it to do.
Thank you so much. Thanks Alot. I got it. I am using 4 RTM in one CPU. And I give all them 0 NR. Thats why it was happening. Now I gave them 0, 1, 2, 3 like this. Now its fixed.
Hello everyone, I've had this issue for the last 2 days where I try to assign the profisafe address to an IO block (6ES7 146-6FF00-0AB0) but when...
59
Hello, good morning, I have been having two problems with the Tia Portal software. The first is that I have installed it on my computer and...
80
Hello to all, I'm just starting with using CodeSys. Immediately, I have noticed that Codesys doesn't use data blocks like for example S7 does...
161
110
330
