Siemens ET200S
Is M13, M14 the output modules that you said there not working?
I don't think the card is bad, since you showed the CPU with no faults.
To test if the output module is working, you can just open hw config and open the monitor/modify window for that one module.
Is the card getting power? The outputs need external power to work, even for the LED's, as far as I know.
Do you have a similar output card anywhere that works? Maybe exchange them to see what works
all the cards are getting power but non of the output card is on not even the analog cards only the input cards are working
On the output modules nothing should be on, unless the output is going high.
A few suggestions, do you know what the outputs are for?
> Check in the logic to see what supposed to trigger those outputs.
> Or force in a VAT table, or HW Config as I showed you before. ONLY IF IS SAFE TO DO SO.
I was trying to communicate between Siemens ET200S IM-151-8 PN/DP CPU to Rockwell Allen Bradley L73 through Hilscher Gateway NT100-RE-EN. Using...
133
Hi there, I'm having major issues in connecting a Siemens S7-300 315 with an ET200S through Profibus. I've tried many methods but I'm really...
2,857
I'm configuring a profinet network in TIA portal v13, comprising the following components: S71500/ET200MP processor TP1200 HMI 2 x IM 155-6 PN...
2,282
Hi all, I have successfully connected my new wirelessHART sensors to the master station, but am struggling to find a comprehensive guide on how...
1,714
Hi all, Hardware: siemens S400 /profibus dp/ ET200s/ IM 151-1 Software: PC using Step7 v5.4 sp2 I'm trying to add more hardware onto an...
6,169
