Setting up DDE from RsLinx to Excel
subscribed to this thread, this seems like a very interesting thread
So Now I'm having a problem in an area that I have already gotten past. I am figuring that a setting has changed. The only thing I can remember doing at some point was rebooting my puter.
Not sure if you got the problem resolved, but here is a video that walks through the process.
https://www.youtube.com/watch?v=uSqsJApBGDs
OG
That was an Awesome video. Thank you. I got er' done. My first issue was that I was using Rslinx Classic Lite, and that had no edit menu. I went and Got Rslinx Single Mode and everything fell into place. You guys are such a Huge help every single time I have to come back here to Visit. Thanks!
Hi all,
Stacked with the same problem. Is this correct that a free Version of RSLinx Classic Lite wouldn't support that?
I've looked for Rslinx Single Mode at Rockwell Website but didn't found this particular name at Downloads.BTW the video above is unavailable.
None of the Lite versions will support it. You Need Classic or higher
I have both Classic Gateway & Classic OEM and it will work on those.
Good morning fellow sea captains and wizards, I am being asked to do the above and obtain 4 values from each slave, I know about the MRX and MWX...
32
961
SELECTED NEW FILE SELECTED PROCESSOR TYPE SELECTED I/O CONFIGURATIONS IM UNABLE TO CONFIGURE MY I/O’S. I HAVE A PAPER COPY OF A PROGRAM AND I...
96
Does Rockwell still offer reset codes for old school Master Disk floppy's? In a bind and need to reset the activation disk soon and to be pointed...
266
Hello, I am in possession of a WAGO PFC 200 750-8216 which I was successfully able to set up as a Modbus RTU Master to a slave device using...
99
Hello. I am trying to use a Prosoft AN-X4 to improve the communications for a new panelview plus 7. This is going from a SLC-500 through DH+ to a...
311
