Scada Example (Ignition)
damica1
Aug 2015
Illinois
839
Hello:
I just thought some of you may want to see a report that we take from Ignition Scada.
I work in the Oil & Gas Industry and this is a report that tells us how much money it cost to operate certain pumping unit out in the remote oilpatch.
We use this report to help show us when pumping units become out of "Balance", this is an easy fix and it saves us Hundreds of Thousands of Dollars each year.
I’m not a oil guy, I am curious to know what an unbalanced well is and how do you correct that?
I still remember the first oil pump I saw when I was little.
The rod going into the ground was covered and decorated as a earthworm and the pump was painted as a bird.
Every pump I have seen since seems to be missing that.
The company I work for is the crawling stage with Ignition. We build refrigerated trailers. I think having a screen similar to this would be nice to see the efficiency of the process.
Hello, im quite new and still learning. I would like to ask is it possible for FATEK PLC to read data value more than 16k? I'm trying to move my...
74
Hello, the system we use is Scada 7.5 series. We have usb key activ now we need additional key to make the system work, how do we solve this...
86
Hi, We have been facing a issue with SCADAPack 474. Configuration is like below. RTU 474 + 6103 PS + 5606 IO Mix Module + 5414 DI Module Only...
78
Hello guys please I want experience with this I am currently working on a scada project using FTView SE and I have an Ethernet IP local area...
51
110
