S7/TIA Portal: HMI KTP1200 "Virtual Keypad is too small" says operator...
Mas01
Oct 2020
Leicester, England
1,109
...and I agree.
Context: TIA Portal/HMI = KTP1200 (12" screen)
In the attached redacted image, the values in the white boxes are entered by the operator (+ve or -ve numbers to 3dp).
Although the image doesn't show it, on the HMI, when you tap on a data entry field, the on-screen keyboard that appears has got quite small buttons...even I find it difficult to differentiate between the minus sign "-" and the decimal point "." keys.
QUESTIONS:
1. Is there a way to make the HMI on-screen keypad bigger?
2. Is it possible to connect a larger (possibly 3rd party) touchscreen instead of a Siemens HMI? Would something like this would work?
https://www.beetronics.co.uk/27-inch-touchscreen
Thanks in advance.
USB Keyboard?
You can change the onscreen keyboard configuration in the control panel on the screen, which is outside of the runtime and usually only visible when you first power it up.
USB Keyboard?
Only problem with a keyboard is work surface space limitation...It's about half the size of your average coffee table. The PLC and associated hardware is installed on a small trolley on castors and wheeled around.
As for the on-screen keypad configuration, are you talking about this SETTINGS button on the start-up screen? See picture. Unfortunately, I've not got the HMI in front of me, as it's on-site with customer.
FYI, I've got the HMI KTP1200 Basic model if that makes any difference.
Thanks for the reply.
Yes it does, I misread that and stupidly thought it was TP1200 which is a Comfort panel. Those panels run some variation of a Windows OS.
Basic HMIs can still use a USB keyboard but I'm not sure about re-sizing the onscreen keyboard. I generally use the smallest panels for those which means the keyboard fills the screen.
Yes, mine is a 'basic' HMI, not a Comfort panel.
Does anyone know if a 3rd-party HMI like this one can be used with S7-1212C PLC? i.e. to offer a larger on-screen keyboard for data entry?
If it's the same as comfort panels you go into settings as per your pic or by rebooting the screen and catching it before the runtime starts up. There is an option I think called input panel where you can change the screen size and save the size and position.
Cheers for this.
Unfortunately, I've not got the HMI in front of me, it's on-site with customer. If I can find the user manual, I'll see it says anything like that. Thanks
In theory, a 3rd party HMI COULD work with a 1200, but 2 problems:
1) I think that's just a monitor, not an HMI. Basic panels have no video out.
2) most third party HMIs don't support the optimized/symbolic tag access in the 1200, they support the older non-optimized absolute address based S7-300 style protocol. You'd probably need to turn optimized off for any HMI relevant DBs as well as activating "permit access with Put/Get" comms in the HW settings.
Hello all! So I have one project with a S7-1214 and a MTP1500 "Project1" and one project with another S7-1214 "Project2". Both of these PLC:s need...
155
Hi guys I after a bit of advice on Tia portal graphics, I would like to add a conveyor belt graphic to a hmi and the conveyor in the basic...
235
hello every one. i'm new to tiaportal, i have created new project and HMI screen the program works fine with PLC-sim, but when i try to cntrol the...
488
My PLC (S7-1200) and HMI (KTP-1200 Basic) has been delivered on-site to the customer. To be able to do "off-line" updates to the code, I am using...
240
hi everyone. i hope you guys are doing great. i am trying to built communication between aveva intouch hmi 2023 and tia portal v18. i dont have...
608
