S7 300 mmc got defective
Stuwertz
Feb 2018
49
Hi all
In one of my machine the S7 300 64 KB ( 6ES7953-8LF20-0AA0) micro memory card got defective . I already done mmc reset but still issue not solved .. I plan to change new mmc card . I have spare new 128 KB ( 6ES7953-8LG20-0AA0). I have archived back up project . Could some one tell you step by step procedure to use new memory card .
Can I able to use 128 kB on that cpu .
If using STEP 7 V5.x (SIMATIC Manager):
Open SIMATIC Manager
Go to menu File -> Retrieve and follow the steps
Go to Set PG/PC interface and select your device and protocol (ex: PC Adapter(MPI))
When the project is open, select the Station (PLC) you want to download to
Click the download icon
Click Accessible Nodes and make sure you select the correct address of your PLC.
Hello, i am new Here Iam just need to know this will work or not * i am going to make image file of mmc which is password protected and burn...
1,472
Hi all , In my plant using s7 300 pics . 313C , 315 F 2PN/ DP , 317 F2PN / DP , 315 2PN / DP . All plc used micro memory card . How to take the...
13,089
I I've to change cpu 315_2dp to anather one with the same part no. But my first cpu have mmc and the other havnt how what the steps to change cpu...
2,062
Hello, If any one could help me out, how to load the right software TO a S7 300 Series CPU "MMC card" (512KB) which was formatted by Mistake...
6,645
I am using libnodave to communicate with a Siemens S7-300. When I put the PLC into stop mode and remove the MMC the daveReadBytes call never...
5,927
