RSLogix 5000 Trends Controls
Bolatov
Jun 2010
Mty
87
Hello
I put my computer to log all day some equipments, and I want to review certain times, but when I open the log file I cant go to the desired time, I change start time and when I put scroll it goes to the time when the trend started
So must I leave the trend run for 3 hours before I can check the time I need to review?
is there a way to workaround this?
Thanks guys
After you finish your data logging, are you saving the trend?
Do you go to the "Log" menu and save the trend in a format you can import into excel for further analysis?
It sounds like you're trying to use the Logix trend interface for analysis - that might not be the most useful method.
Good luck!
Hello, I am trying to read a barcode scanner input using a cognex dataman 280 barcode reader, store it another string, the compare with another...
102
Hi folks, in the alarm manager of Rslogix 5000, the tag-based alarm has been created. But when I tried to change the condition, it was found the...
203
I am completely stuck on building a ladder program that requires a start button to be pressed 3 times to turn on motor 1. Then motor 2 starts...
20
649
First off, I'm a hobbyist-level programmer, and this program isn't controlling anything anything that could even remotely be considered "life...
18
588
