RSLinx OPC/DDE etc with Excel
cjd1965
Apr 2007
UK
1,659
Hi
I have Linx classic and FT View ME and want to create a config sheet so i can send info from excel into my PLC. I have read various things online and their is a conflict with the info
Do I have all I need (Linx Classic but also with a FT View ME licence) or do I need to get RS Linx Gateway
Sorry if this has been discussed elsewhere just after a definitive answer
If I need Linx Gateway I would be interested in any free/cheap 3rd party tools to do the same thing because would only be used as a config tool
cjd1965,
As far as I know, the Single Node and up RSLinx should support DDE/OPC topics. The lite version won't work of course.
K
Hi thanks. I am looking at the about box in linx. It says RSLinx classic professional and I can open the dde and opc dialogs.
Am I good to go? I don't have a plc to try it with
Yeah you should be good to go. One thing to keep in mind is that only the gateway version will support local and network OPC/DDE server.
Hey Friends. I am currently trying to write approximately 700 tags from FtView13 to an Logix Emulate 5000. I am using rslinx DDE/OPC to create an...
412
Hi, I am gonna use Rslinx classic 3.9 to copy DDE/OPC tags' link from CompactLogix CPU to Excel through Ethernet/IP but It does not show any of...
35
12,127
After using DDE in my PC applications for many years to interface to PLC programs through RSLinx, I'm FINALLY looking at trying to use a more up...
3,639
Hello, so i am using the RSLing COPY OPD/DDE LINK to import a couple of tags into excel. Very simple, i know, i have done it a hundred times. The...
1,307
I remember reading a thread that explained how to use a remote PC running RSLinx Classic as a server to allow an Ecxel spreadsheet running on...
8,343
