Rs500 sqo hold position after stop and restart
The Rockwell step instructions have always been clunky. Nothing as straight forward as a drum. Anyway... with Rockwell software, I always just roll my own. Easier to read, easier to follow at 2am, and easy to modify.
So if I am on step two and the timer has timed for 4 seconds when stop pushbutton is pressed once I hit restart it goes to the next step but the timer is still at the accumulated value of the last step so it will only time for whatever is left on the timer.i need it to stay in the position it was in at before the stand retain the value of timer after restart
Your MCR may be your problem.
Timers (TONs and RTOs) add to their .ACC each time they are scanned.
If you aren't scanning your RTO because the Stop jumps over the MCR, then when Start is applied the MCR is back on and the RTO will accumulate from the last time it was scanned, which could be minutes ago and thus set .DN, and advance the sequence because .ACC > 8 sec.
If your sequence is held and you aren't scanning the RTO, OTU the Timer .EN bit. Then when the RTO "wakes up", it will recognize a false-to-true transition of its .EN, and not count all the time it was asleep.
I think @Aarwizz nailed it.
The PLC cares not a whit what you want it to do, but it will mercilessly and inexorably do exactly what you tell it to do.
If you want a Stop press/Start press sequence to abort the current step and jump to the next step, then you need to tell the PLC to do just that.
Is this a homework assignment?
I had missed post #12. Can you post the assignment description? We won't supply code, but we can give hints.
I am reasonable familiar with with rs500 sequencers (by no means an expert) but this format of addressing the file on a SQO has me stumped...
1,534
I have upgraded an old RS500 project to Studio 5000, it has thrown multiple errors which I am currently working through. I have looked through...
1,728
I am working on upgrading a system with a ML1500 that uses a 1769-SDN DeviceNet Scanner to a CompactLocix L24ER-QB1B. Due to cost, I need to...
1,405
I have been ask to check if we can have both English and Chinese in the same I/O description text window and rung comments. I could not Chinese to...
1,214
Hi all, Here's an easy one. I've been asked to change a mitsubishi FX plc to a AB1400 using the same program. My customer has emailed me the...
1,626
