RS485 -> USB converters
Aminesnou
Feb 2024
France
Hello,
I'm working on a protocol named "BitBus" which use a SDLC protocol for encapsulation.
This protocol contains start & End Flag, but when i want to do my mesurements with the hardware protocol (RS 485 - USB) converters and with the software "Matlab Serial explorer" I can not find these flags.
I need you help
Hello.
I am not familiar with either BitBus nor MatLab, but I have some experience with serial buses.
It does not seem that the SDLC protocol encapsulation is supported by the Matlab Serial explorer.
I would say you would save yourself a lot of time if you use a product developed for this purpose such as the one below:
USB-BIT - ELZET80 Mikrocomputer GmbH&Co., KG
Hello.
Thank you for your response !
I have several scales with USB output. How can I connect it to my PLC that has RS485 input? There are hundreds of USB to RS485 converters but...
18
6,191
Kindly, we are trying the USB-485 (USB TO RS 485 converter) to access online, a Delta Plc SS2 through its serial port. But, we are getting an...
1,946
Hi all, I have a SLC 5/02 that's been gathering dust for the past couple years that I want to have some fun with. The only problem is I don't...
3,918
Here is a post that we recently completed on the Automation Direct USB to RS485 Adapter. The USB-485M is a 2-wire USB to RS-485 serial...
2,228
I am attempting to perform serial communication with a Thermo-Scientific oil heater's USB port using RS485 communication. I have found a two wire...
1,295
